[mapguide-trac] #780: if RasterGridSize is less than MinRasterGridSize, raster re-projection should still work
MapGuide Open Source trac_mapguide at osgeo.org
Fri Nov 28 16:18:15 EST 2008
should still work
   Reporter:  tonyfang  |       Owner:  tonyfang
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:  2.0.1
   Severity:  minor     |    Keywords:
External_id:  1167124   |
 In the serverconfig.ini, set RasterGridSize to something smaller than
 MinRasterGridSize.
 I will modify the TransformMesh class so that it will check to make sure
 the MinRasterGridSize is less than the RasterGridSize. If
 MinRasterGridSize is greater than RasterGridSize, than the
 MinRasterGridSize setting will be ignored.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/780>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
