[mapguide-trac] #720: Problem with coordinate system
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 7 12:55:52 EDT 2008
   Reporter:  ssnc     |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  Maestro  |     Version:  2.0.1
   Severity:  blocker  |    Keywords:
External_id:           |
 I made a map with 'MapGuide Maestro' about some data (the format of the
 data is shp, not sdf), but when I use the operation 'buffer' it doesn´t
 create the buffer and a warning appears ("Warning: 1 layers were excluded
 from buffer computation because their coordinate systems are incompatible
 with the coordinate system of the map, or because they have no coordinate
 system at all"). I can´t open the section of 'Coordinate System' of
 MapGuide Maestro (the next exception appears:
 "Consulte el final de este mensaje para obtener más detalles sobre cómo
 invocar a la depuración
 Just-In-Time (JIT) en lugar de a este cuadro de diálogo.
 ************** Texto de la excepción **************
 System.Net.WebException: El servidor ha cometido una infracción de
 protocolo. Section=ResponseHeader Detail=CR debe ir seguido de LF
    en System.Net.WebClient.OpenRead(Uri address)
    en System.Net.WebClient.OpenRead(String address)
    en OSGeo.MapGuide.MaestroAPI.CoordinateSystem.get_Categories()
    en
 OSGeo.MapGuide.Maestro.ResourceEditors.SelectCoordinateSystem..ctor(ServerConnectionI
 connection)
    en
 OSGeo.MapGuide.Maestro.ResourceEditors.MapEditor.btnSelectCoordSys_Click(Object
 sender, EventArgs e)
    en System.Windows.Forms.Control.OnClick(EventArgs e)
    en System.Windows.Forms.Button.OnClick(EventArgs e)
    en System.Windows.Forms.Button.WndProc(Message& m)
    en System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&
 m)
    en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
 IntPtr wparam, IntPtr lparam)
 ************** Ensamblados cargados **************
 mscorlib
     Versión del ensamblado: 2.0.0.0
     Versión Win32: 2.0.50727.1434 (REDBITS.050727-1400)
     Código base:
 file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
 Maestro
     Versión del ensamblado: 1.0.9.15910
     Versión Win32: 1.0.9.15910
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/Maestro.exe
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
 System
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
 System.Drawing
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
 Globalizator
     Versión del ensamblado: 1.0.9.0
     Versión Win32: 1.0.9.0
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/Globalizator.DLL
 System.Xml
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
 System.Windows.Forms.resources
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
     Versión del ensamblado: 1.0.9.15907
     Versión Win32: 1.0.9.15907
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.MaestroAPI.DLL
 OSGeo.MapGuide.Maestro.MaestroEditorInterface
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.MaestroEditorInterface.DLL
 mscorlib.resources
     Código base:
 System.Configuration
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
 dryndx0c
     Código base:
 System.Web
     Código base:
 file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
 mlsmv3o5
     Código base:
 lzdf_i5b
     Código base:
     Versión del ensamblado: 1.0.9.15908
     Versión Win32: 1.0.9.15908
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.ResourceEditors.DLL
 OSGeo.MapGuide.Maestro.FusionEditor
     Versión del ensamblado: 1.0.9.15909
     Versión Win32: 1.0.9.15909
     Código base:
 file:///C:/Program%20Files/HexaD/MapGuide%20Maestro/OSGeo.MapGuide.Maestro.FusionEditor.DLL
 9e5x064v
     Código base:
 k6no_bz9
     Código base:
 1pnf3tzf
     Código base:
 System.resources
     Código base:
 file:///C:/Windows/assembly/GAC_MSIL/System.resources/2.0.0.0_es_b77a5c561934e089/System.resources.dll
 ************** Depuración JIT **************
 Para habilitar la depuración Just In Time (JIT), el archivo de
 configuración de esta
 aplicación o equipo (machine.config) debe tener el
 valor jitDebugging establecido en la sección system.windows.forms.
 La aplicación también se debe compilar con la depuración
 habilitada
 Por ejemplo:
 <configuration>
     <system.windows.forms jitDebugging="true" />
 </configuration>
 Cuando esté habilitada la depuración JIT, cualquier excepción no
 controlada
 se enviará al depurador JIT registrado en el equipo
 en lugar de controlarlo mediante el cuadro de diálogo."),
 I use webstudio to modify the coordinate system but with the three default
 coordinate systems that appears ((epsg:4269)NAD83,(epsg:4326)WGS 84 and
 (epsg:42304)NAD83/NRCan LCC Canada) it occurs the same warning. How can I
 know the coordinate system of my data?.
 Thanks.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/720>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
