[mapguide-trac] #463: Fusion: Tooltips do not work for any flexible layout with any layer source
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 7 15:27:06 EDT 2008
 Reporter:  amorsell  |         Owner:  chrisclaydon
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:
Component:  Fusion    |       Version:  2.0.0
 Severity:  critical  |    Resolution:
 Keywords:            |   External_id:
Comment (by madair):
 may be related to http://trac.osgeo.org/fusion/ticket/64, but the error
 I'm seeing is only with tiled maps
 Tracing the error into the source file (line 1041 of
 ServerRenderingService?.cpp) reveals that MGOS is making a call to
 map->GetViewCenter?() which seems to be failing probably because the map
 extents have not been set for tiled layers.
 To test this theory, I did a QUERYMAPFEATURES call first (which failed as
 above), then I made a call to GETVISIBLEMAPEXTENTS using the web tier test
 page, and then re-issued the same QUERYMAPFEATURES request and it worked
 properly.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/463#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
