[mapguide-trac] #465: Rendering enhancement: user-defined palettes for PNG8
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 14 13:04:31 EDT 2008
 Reporter:  jbirch             |         Owner:
     Type:  enhancement        |        Status:  new
 Priority:  medium             |     Milestone:
Component:  Rendering Service  |       Version:
 Severity:  major              |    Resolution:
 Keywords:                     |   External_id:
Comment (by jbirch):
 You start running into problems with this if you're using transparency or
 raster layers.  I wonder if the number of cases where enumerating the
 styles wouldn't be sufficient is large enough that you'd want to avoid
 implementing it as a partial solution (raises more questions than it's
 worth?)
 My preferred solution would be a tool that gridded the map at each visible
 scale range, visited each tile, and generated a custom palette for that
 scale range from the colours in those tiles.  Hopefully, there would be a
 way of tweaking this so that commonly occurring colours don't totally
 exclude uncommon but important (nothing else close to them) colours.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/465#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
