[mapguide-trac] #720: Problem with coordinate system
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 14 16:12:37 EDT 2008
 Reporter:  ssnc     |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  medium   |     Milestone:
Component:  Maestro  |       Version:
 Severity:  blocker  |    Resolution:
 Keywords:           |   External_id:
Comment (by ksgeograf):
 This is not really a great forum to handle multiple questions, but here
 goes:
 1. Session expired usually means that you have not used the machine for at
 while, or that the MapGuide service restarted.
 2. I would like just the shape data. You can send it to
 opensource_x_hexad.dk (replace _x_ with @).
 3. The "Resource not found" is probably due to a bug in WebStudio.
 4. Do you have a "primary key" on the data?
 5. I have not used such a service, but you can ask on the MapGuide mail
 list for that. I know MapInfo has one called "Evinsa".
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/720#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
