[mapguide-trac] #705: MapGuide does not clean up temporary files
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 17 03:53:33 EDT 2008
 Reporter:  ksgeograf                        |         Owner:
     Type:  defect                           |        Status:  new
 Priority:  low                              |     Milestone:
Component:  General                          |       Version:  2.0.1
 Severity:  trivial                          |    Resolution:
 Keywords:  temporary files C:\windows\temp  |   External_id:
Comment (by ksgeograf):
 I just experimented, and this problem is reproduceable:
 1. Delete all files from C:\Windows\temp
 2. Open Maestro
 3. Open a resource (eg. Map).
 4. Save the resource
 A new file appears in C:\windows\temp
 To make sure the problem isn't Maestro, I just tried this with Studio, and
 it has the same behavior. I tried monitoring the mgserver.exe process, and
 it does not appear to have a handle to any of the created files, so the
 problem is most likely in the web tier.
 I have none of the IDFxxx.tmp files in C:\Windows\temp.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/705#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
