[mapguide-trac] #726: MapGuide Stops Listening on 2811 (Client Connections)
MapGuide Open Source trac_mapguide at osgeo.org
Sat Oct 18 00:29:34 EDT 2008
   Reporter:  rbranson  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  Server    |     Version:  2.0.2
   Severity:  trivial   |    Keywords:
External_id:            |
 Here's what I've got going:
 * MapGuide 2.0.2 on Windows 2008 Server 32-bit w/2GB RAM.
 * 4x2.66GHz Core 2 Duo
 * Using the installers with Apache
 My client "application" is OpenLayers with THREE Layers that connect to
 MapGuide. We're needing to switch the content of the "middle" layer in our
 sandwich out so there's a lot of concurrent connections going on.
 The majority of the data set is worldwide vector geography down to
 1:500,000. The feature sources are base oceans (just a square out to the
 extents), water polygons, water lines (very, very small rivers), nations,
 administrative areas, built-up areas (like metro areas), cities (187k of
 these), shorelines, national boundary lines, major routes, minor routes,
 and cities. Layers are created from these, up to 9 layers are pointed at a
 single source (in the case of cities because we have 9 significance
 levels) and we use some simple filter rules to get the features we want
 into each layer.  We're not using any theming and instead we're breaking
 anything that would fall under the "theming" concept into separate layers.
 We just find that easier to manage. The "sandwich" layers are vector RF
 contours. These are "relatively" simple as they're really only useful down
 to 1:1,000,000 usually. All of it is in the same projection and I've
 double/quadruple verified all of this. All of this was imported from SHP
 files and converted to SDF upon import.
 I've got one custom little PHP piece that that finds cities by name and
 any RF patterns that spatially match. This was originally a source of
 problems because I wasn't closing my feature readers. That has been fixed.
 I thought maybe this was "triggering" the problem, but I could reproduce
 the problem without touching the PHP script.
 My problem is that after some load is applied to the system, the MapGuide
 stops listening on port 2811, requiring a restart of the server process to
 get it back. The bizarre thing is that the current connections (from the
 map agent running in the apache process to the mg server) stay open so for
 a little while some of the queries go thru. Eventually they all timeout
 and things go south. The pattern seems to be when I swap that sandwich
 layer out and then immediately zoom down to a city point (this is
 replicated from the search results from that custom PHP piece). Vancouver,
 BC is particularly bad because it happens to pull features out of almost
 all of the layers. The admin (2810) and site (2812) ports continue to stay
 listening.
 I'm not seeing anything in the error logs. I tried to use the trace
 logging but nothing really came of that. I spent a couple of hours tuning
 the serverconfig.ini and I could find ways to make some small progress but
 the port would eventually just stop listening. Most of my focus was
 playing with the thread, queue, and max connections for both client and
 site as well as the data connection pooling / caching features. I just
 reverted back to using the default serverconfig as a "control." I tried to
 single out a layer that was causing problems, but none of them appeared to
 be causing problems. Even taking the majority of the layers down out would
 "put off" the problem for a little while, but eventually after enough
 requests it would surface.
 I spent some time burning thru the source code and learning how it was all
 interconnected to see why it would just suddenly stop listening on a port,
 but I eventually got down in abstraction to the ACE framework and my
 morale sank. ACE seems really nifty, but tracing thru their source code
 was a little daunting :)
 The only workaround that actually succeeded was editing the Apache
 configuration to limit the ThreadsPerChild value. I believe the default
 was 20. I dropped this to 12 and inched it up to 16 without problems. This
 is where I left it because the performance was ACCEPTABLE. Granted, it was
 a bit better with the default (better parallelism) but slower is better
 than eventual crashing.
 So I've "fixed" the problem but it seems somewhat like a copout on my
 part. is this some kind of locking problem with too many FDO connections
 trying to access the same data source? I'd love to help in any way.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/726>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
