[mapguide-trac] #732: Advanced placement problems
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 24 00:31:24 EDT 2008
   Reporter:  zspitzer           |       Owner:
       Type:  defect             |      Status:  new
   Priority:  low                |   Milestone:
  Component:  Rendering Service  |     Version:  2.0.2
   Severity:  major              |    Keywords:
External_id:                     |
 I have been having some problems with advanced placement
 Attached package contains
 example 1 : aug O6 ROADS - FWY - WITH ADVANCED PLACEMENT SET LESS THAN
 ZERO (This shows text scaling in the dynamic state, following the road)
 example 2 : aug O6 ROADS - FWY - WITH ADVANCED PLACEMENT SET 1.0 (This
 shows text still scaling even though it should not scale but remain at the
 size set)
 With Example 2 : If the text is set as 1.0 (do not scale) it should still
 follow/curve with the road line and only display if it fits within the
 length of the road, it should not scale to fit. I would prefer text to
 only display if the length of the text string fits within the road segment
 length but also follows the curve of the road.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/732>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
