[mapguide-trac] #735: LineBuffer::Optimize doesn't return buffer of same geometry type
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 24 16:44:58 EDT 2008
   Reporter:  waltweltonlair    |       Owner:  waltweltonlair
       Type:  defect            |      Status:  new
   Priority:  high              |   Milestone:  2.1
  Component:  General           |     Version:  2.0.1
   Severity:  major             |    Keywords:
External_id:  1117732, 1099343  |
 The LineBuffer::Optimize method creates and returns an "optimized"
 !LineBuffer which contains a reduced set of points based on the supplied
 drawing scale.  The returned buffer must be the same geometry type as the
 source buffer, but the code isn't ensuring this is the case.  This is
 resulting in rendering glitches.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/735>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
