[mapguide-trac] #736: Add unit tests for TransformMesh class (used by Raster Re-projection)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Oct 24 17:01:27 EDT 2008
   Reporter:  tonyfang  |       Owner:
       Type:  task      |      Status:  new
   Priority:  medium    |   Milestone:
  Component:  Server    |     Version:  2.0.1
   Severity:  minor     |    Keywords:
External_id:            |
 I will add some unit tests for this class. They will be part of the
 server's unit test.
 You will be able to run the tests with the following command:
 mgserver.exe test transformmesh
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/736>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
