[mapguide-trac] #739: Better failure description for WFS service
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 27 08:53:44 EDT 2008
   Reporter:  ksgeograf        |       Owner:
       Type:  defect           |      Status:  new
   Priority:  low              |   Milestone:
  Component:  Feature Service  |     Version:  2.0.2
   Severity:  minor            |    Keywords:
External_id:                   |
 When a FeatureSource is exposed as WFS, it must function, otherwise the
 "GetCapabilitites" call fails. This should be fixed, and the error should
 be logged, and the feature removed from the GetCapabilitites response.
 The currently logged message should be improved to include the resourceId
 of the failed featuresource. Currently I get this:
 <2008-10-27T13:43:42>           127.0.0.1       WfsUser
  Error: An exception occurred in FDO component.
         Connect failed:
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation line 83 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_30.6\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
   - MgOpDescribeSchema.Execute line 105 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_30.6\mgdev\server\src\services\feature\OpDescribeSchema.cpp
   - MgServerDescribeSchema.DescribeSchema line 545 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_30.6\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
   - MgServerDescribeSchema.ExecuteDescribeSchema line 176 file
   - MgFdoConnectionManager.Open line 858 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_30.6\mgdev\server\src\common\manager\FdoConnectionManager.cpp
 Connect failed:
 Seeing that I have +100 FeatureSources, and no idea which ones are exposed
 as WFS it will take half a day to find the culprit.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/739>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
