[mapguide-trac] #740: GETSPATIALCONTEXTS and GDAL Always Returns Default Extents
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 28 08:06:12 EDT 2008
 Reporter:  crispinatime     |         Owner:
     Type:  defect           |        Status:  new
 Priority:  medium           |     Milestone:  2.1
Component:  Feature Service  |       Version:  2.0.2
 Severity:  major            |    Resolution:
 Keywords:                   |   External_id:
Comment (by ksgeograf):
 I have spent some time debugging Maestro myself, and at that point it
 seemed to work.
 There are some test files here:
 http://trac.osgeo.org/mapguide/ticket/601
 I found that GDal reports the default extents, when it should have
 reported an error.
 Can you get correct extents with the files from #601?
 You may also want to try running MapGuide in interactive mode with GDal
 debug turned on:
 http://trac.osgeo.org/fdo/wiki/FdoGdalNotes
 It will show some extra info that GDal outputs when it loads your data.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/740#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
