[mapguide-trac] #741: DWF layers are rendered upside down
MapGuide Open Source trac_mapguide at osgeo.org
Tue Oct 28 18:42:28 EDT 2008
 Reporter:  tonyfang           |         Owner:  tonyfang
     Type:  defect             |        Status:  closed
 Priority:  medium             |     Milestone:
Component:  Rendering Service  |       Version:  2.0.1
 Severity:  minor              |    Resolution:  fixed
 Keywords:                     |   External_id:  1126575 and 1126554
Changes (by tonyfang):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Before, AGGW2DRewriter.cpp needed to flip the height to get the DWF layers
 to render properly.
 When DWF layers are rendered, it calls AGGRenderer's DrawScreenRaster.
 This code was changed in the raster re-projection implementation.
 AGGW2DRewriter's agr_process_image and agr_process_pngGroup4Image do not
 need to flip the height in their calls AGGRenderer::DrawScreenRaster.
 http://trac.osgeo.org/mapguide/changeset/3416
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/741#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
