[mapguide-trac] #745: Error Theming Layer using data source with feature joins
MapGuide Open Source trac_mapguide at osgeo.org
Thu Oct 30 18:45:30 EDT 2008
 Reporter:  CivilEng                |         Owner:
     Type:  defect                  |        Status:  new
 Priority:  high                    |     Milestone:  2.1
Component:  Web API                 |       Version:  2.0.1
 Severity:  critical                |    Resolution:
 Keywords:  Theming, feature joins  |   External_id:
Old description:
> The error is raised when individual distribution is requested.
> MgFeatureAggregateOptions aggregateOptions = new
> MgFeatureAggregateOptions();
> aggregateOptions.AddFeatureProperty(UFunctions.GetParameter(this.args,
> "PROPERTYNAME"));
> aggregateOptions.SelectDistinct(true);
> // this line raises the exception
> dataReader = featureService.SelectAggregate(resId,
> layer.GetFeatureClassName(), aggregateOptions);
> Error: Index is out of range.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpSelectFeaturesSpatial.Execute line 110 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
>   - MgServerSelectFeatures.SelectFeatures line 249 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
>   - GetItem line 81 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\common\foundation\System/DisposableCollection.cpp
> I am attaching mgp file and access database in order to replicate the
> error.
> the mgp contains the flexible(fusion) and basic layout. Both layouts
> invoke to thememain.aspx (It's the same that comes with the
> dotnetviewersample).
> I have tested for manage and unmanage data source, just as SHP, SDF, and
> SQL2008 providers.
New description:
 #!cpp
 "PROPERTYNAME"));
 StackTrace:
 error.
 SQL2008 providers.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/745#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
