[mapguide-trac] #1062: Installer: add step to set the MapGuide application pool to 32 bit mode
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 5 17:14:46 EDT 2009
   Reporter:  jbirch     |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  2.1
  Component:  Installer  |     Version:  2.1.0
   Severity:  major      |    Keywords:
External_id:             |
 On 64bit machines, the !MapGuide and PHP ISAPI modules will fail if the
 application pool is running in 64bit mode.  The installer needs to add a
 step to set to 32bit mode.
 IIS6:
 http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Library/IIS/
 405f5bb5-87a3-43d2-8138-54b75db73aa1.mspx?mfr=true
 IIS7:
 http://www.iis.net/ConfigReference/system.applicationHost/applicationPools/add
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1062>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
