[mapguide-trac] #1072: PHP CLI errors out under Windows 2008 / Vista when MapGuide extension loaded
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 17 16:00:34 EDT 2009
loaded
 Reporter:  jbirch    |         Owner:
     Type:  defect    |        Status:  new
 Priority:  medium    |     Milestone:
Component:  Web API   |       Version:  2.1.0
 Severity:  minor     |    Resolution:
 Keywords:  php, cli  |   External_id:
Changes (by jbirch):
  * priority:  high => medium
  * severity:  major => minor
Comment:
 Found a workaround.  This is not really an acceptable solution, but good
 enough to lower the priority of the ticket.
 Add the following DWORD values to the registry:
 HKLM\Software\Microsoft\Windows\Windows Error Reporting\DontShowUI = "1"
 HKLM\Software\Microsoft\Windows\Windows Error Reporting\Disabled = "1"
 Unfortunately, this entirely disables the WER UI and stops the reports
 from being sent to MS.  Maybe not a problem on a dedicated server, but on
 a shared server often you want reports in things like MSSQL and ASP.Net
 sent to MS.
 References:
 http://stackoverflow.com/questions/396369/how-do-i-disable-the-debug-
 close-application-dialog-on-windows-vista
 http://msdn.microsoft.com/en-us/library/bb513638(VS.85).aspx
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1072#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
