[mapguide-trac] #1061: HttpHandler's GetIdentityProperties throws an unimplemented exception
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 24 11:31:01 EDT 2009
 Reporter:  jbirch     |         Owner:  brucedechant
     Type:  defect     |        Status:  assigned
 Priority:  medium     |     Milestone:  2.1
Component:  Map Agent  |       Version:  2.1.0
 Severity:  major      |    Resolution:
 Keywords:             |   External_id:
Changes (by brucedechant):
 * cc: trevorwekel (added)
Comment:
 The fix for this is to restore the original API signature that was removed
 with the patch for ticket 1002. Even though the HTTP API is not documented
 any changes to it should require an RFC.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1061#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
