[mapguide-trac] #1077: GCC 4.x builds libMapGuideJavaApi.so incorrectly and causes TomCat to crash
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 28 12:47:53 EDT 2009
 Reporter:  brucedechant  |         Owner:  brucedechant
     Type:  defect        |        Status:  assigned
 Priority:  high          |     Milestone:  2.2
Component:  Build System  |       Version:
 Severity:  critical      |    Resolution:
 Keywords:                |   External_id:
Old description:
> The GCC 4.x compiler generates code that causes the built
> libMapGuideJavaApi.so to crash TomCat when the Java viewer is used.
> The fix for this is that the SWIG generated code needs to be compiled
> with the following compiler setting:
> -fno-strict-aliasing
New description:
 libMapGuideJavaApi.so to crash !TomCat when the Java viewer is used.
 The fix for this is that the SWIG generated code needs to be compiled with
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1077#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
