[mapguide-trac] #1170: Maestro: considering warning user when encountering unfamiliar elements, give option to open as XML instead
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 2 13:50:44 EST 2009
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 I'm generating a lot of code in layer definitions that Maestro does not
 recognize in order to support complex stylization.
 It would be useful if Maestro would warn when opening these hand-tweaked
 resources and prompt the user whether they want to open the XML editor
 instead of the GUI editor.
 I'm worried that either I or one of the other admins here will
 accidentally create some pretty odd layers or not understand why something
 is working the way it is.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1170>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
