[mapguide-trac] #1172: Improve legend performance by using GetResourceContents() API
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 3 17:40:59 EST 2009
 Reporter:  brucedechant  |         Owner:  brucedechant
     Type:  defect        |        Status:  assigned
 Priority:  low           |     Milestone:  2.2
Component:  Viewer API    |       Version:  2.1.0
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Changes (by brucedechant):
  * status:  new => assigned
Old description:
> The viewers generate the legend by executing a series of
> GetResourceContent() API requests - one for each layer of the map. This
> can impact performance significantly if the map contains lots of layers.
> By using the NEW GetResourceContents() API we can reduce the number of
> requests to generate the legend from the number of layers in the map to
> just 1.
New description:
 !GetResourceContent() API requests - one for each layer of the map. This
 By using the NEW !GetResourceContents() API we can reduce the number of
 just 1.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1172#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
