[mapguide-trac] #1175: Failed to set map name using MgMap.Open
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 3 20:53:54 EST 2009
   Reporter:  liuar    |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.0.2
   Severity:  trivial  |    Keywords:
External_id:           |
 a.Assume we have a MapDefinition called
 “Library://Test/Default.MapDefinition”;[[BR]]
 b.We create the map using the following code:[[BR]]
     MgMap map = new MgMap();
     map.Create(resourceService, new
 MgResourceIdentifier(“Library://Test/Default.MapDefinition”),
 “Default1234”);
     map.Save();
 c.In other code, we want to use this map, so we use this code:[[BR]]
     map.Open(resourceService, “Default1234”);
 d.Now the Name property for map in step c) is supposed to be
 “Default1234”. However, you’ll find it’s still “Default”, the name of map
 definition, not the name of map.[[BR]]
 If you open the code of
 “\\trunk\MgDev\Common\MapGuideCommon\MapLayer\Map.cpp”, you’ll find the
 line 504 and 505 is like this:[[BR]]
     m_name = mapName;
     MgResource::Open(m_resourceService, resId);
 However, MgResource::Open will use the name of map definition, not the
 name of map to replace the value of m_name.[[BR]]
 So we should put “m_name = mapName;” behind “MgResource::Open”.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1175>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
