[mapguide-trac] #1194: Fusion: Fail to narrow Task pane when drag the Vertical Line
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 9 11:20:57 EST 2009
   Reporter:  madair            |       Owner:
       Type:  defect            |      Status:  new
   Priority:  low               |   Milestone:
  Component:  Fusion Templates  |     Version:  2.0.2
   Severity:  trivial           |    Keywords:
External_id:  1254170           |
 from Fusion trac #287
 The splitter beside the task pane fails to allow dragging depending on
 where the mouse is,
 solution is to put zIndex: -1 in the jxPanelContentContainer class
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1194>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
