[mapguide-trac] #1189: Unable to connect to WMS. Maestro R4358 Beta
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 12 04:54:22 EST 2009
 Reporter:  neilw          |         Owner:  ksgeograf
     Type:  defect         |        Status:  closed
 Priority:  low            |     Milestone:
Component:  Maestro        |       Version:  2.0.2
 Severity:  major          |    Resolution:  fixed
 Keywords:  Maestro r4358  |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed with r4420.
 Issue #1149 was fixed in r4418.
 I have reported the underlying issue (that the errors occur) as issue
 #1197.
 The next problem (reported on the mailing list) is that the LayerEditor
 does not show the raster columns.
 The problem is that the WMS provider passes on the XSD more or less
 unmodified from the WMS source, and that the WMS source you posted uses
 inherited class definitions. I have now updated the reader to support this
 type of XSD and the raster columns show up as expected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1189#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
