[mapguide-trac] #1151: Maestro: Consider adding basic support for SymbolDefinition
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 12 14:29:50 EST 2009
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  medium       |     Milestone:
Component:  Maestro      |       Version:
 Severity:  minor        |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed with r4427.
 The xml editor now includes a resource data editor where applicable,
 including in the symbol definition editor.
 The open problem was due to an poor implementation of the templates, this
 is now fixed.
 If you want both a composite and simple template, you can add them to the
 templates folder of your installation. If you want them to be part of the
 standard Maestro installation, please add them to a ticket.
 Also fixed a formating issue when opening certain resources.
 It was not possible to edit resource data, because the resource editors
 always used the actual resource, so a "cancel" would not undo the resource
 data changes.
 Maestro is now using temporary resources for everything, so cancel works
 as expected.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1151#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
