[mapguide-trac] #1170: Maestro: considering warning user when encountering unfamiliar elements, give option to open as XML instead
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 12 18:31:38 EST 2009
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:  Maestro-2.0
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Fixed with r4429.
 I added a check and a warning message.
 Due to the seperation between the resource editors and the main
 application, it is not currently easy to open the resource as an xml.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1170#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
