[mapguide-trac] #1183: Maestro: update affected resources does not work for SymbolDefinitions
MapGuide Open Source trac_mapguide at osgeo.org
Sat Dec 12 19:18:49 EST 2009
 Reporter:  jbirch   |         Owner:  ksgeograf
     Type:  defect   |        Status:  closed
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:  fixed
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed with r4430.
 This was due to the composite references that are constructed slightly
 different.
 I changed the resource update system to use the xml documents in raw,
 rather than the .Net objects, as this makes it much easier to find the
 ResourceId's. It also has the benefit that the .Net
 serialization/deserialization won't accidentially remove fragments.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1183#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
