[mapguide-trac] #1199: Maestro: r4431 has does not initialize colorbrewer correctly when first column chosen is string
MapGuide Open Source trac_mapguide at osgeo.org
Sun Dec 13 05:03:51 EST 2009
   Reporter:  jbirch   |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 With the attached (hopefully) file, when trying to theme if I choose the
 integer KEY column first and then choose one of the string columns (name,
 category, etc) I can successfully initialize a Color Brewer theme.  If I
 choose one of the string columns without first choosing the integer column
 first the Color Brewer boxes are not populated with colour swatches and
 when I try to select the radio button Maestro crashes.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1199>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
