[mapguide-trac] #1202: Maestro: UI performance when hovering over tabs
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 14 12:31:08 EST 2009
   Reporter:  jbirch   |       Owner:  ksgeograf
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 There is a bit of a weird glitch in the Maestro UI.  If you click on a tab
 and then hover over it while waiting for the resource editor to repaint,
 the repaint is painfully slow.  This occurs for both the XML editor and
 the custom editors.  It appears that the UI is giving priority to
 refreshing the tab's maptip or something like that, since the maptip keeps
 flashing.
 Moving the mouse pointer away from the tab bar after clicking on a new tab
 causes the UI to refresh almost instantaneously.  This isn't a big deal if
 you know to move your mouse away from the tab after clicking on it, but
 for the longest time I just thought the repaint was intrinsically slow.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1202>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
