[mapguide-trac] #1207: Maestro: consider adding new Layer to highlighted folder in Map
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 15 19:09:35 EST 2009
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 Currently, when you add a new layer to a map, it always shows up at the
 bottom of the list.  It would be nice if, when a folder is highlighted in
 the tree, the added layer could be added directly to that folder.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1207>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
