[mapguide-trac] #1208: SelectFeatures doesn't work if filter is secondary property
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 16 02:23:20 EST 2009
   Reporter:  christinebao     |       Owner:  Christine Bao
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:
  Component:  Feature Service  |     Version:  2.1.0
   Severity:  major            |    Keywords:
External_id:  1282026          |
 Steps to reproduce:[[BR]]
 (The following data names are for explanation and understanding. You can
 use any data as needed)
 [[BR]]
 Open MapGuide Studio:
 1. Connect to Primary.SDF, assuming it has properties: ID, Name.[[BR]]
 2. Connect to Secondary.SDF, assuming it has properties: ID, Code.[[BR]]
 3. Open Primary.FeatureSource, create a join with following
 conditions:[[BR]]
     Extension name is: Join_Extension[[BR]]
     Primary.ID = Secondary.ID[[BR]]
     One-to-one[[BR]]
 4. View the extension data in MapGuide FeatureSource editor, and there are
 properties: ID, Name, SecondaryID, SecondaryCode. Please note the last
 two, they are from secondary table, and the property name is formatted by
 "Secondary table name" + "Property name".[[BR]]
 5. Use MapGuide agent to test FeatureService -> SelectFeatures:[[BR]]
    a. If use property from primary table as filter, for example "ID=1",
 the result is right.[[BR]]
    b. If use property from secondary table as filter, for example
 "SecondaryID=1", there is an exception: FDO can't execute query.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1208>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
