[mapguide-trac] #1208: SelectFeatures doesn't work if filter is secondary property
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 16 02:42:37 EST 2009
 Reporter:  christinebao     |         Owner:  Christine Bao
     Type:  defect           |        Status:  new
 Priority:  medium           |     Milestone:
Component:  Feature Service  |       Version:  2.1.0
 Severity:  major            |    Resolution:
 Keywords:                   |   External_id:  1282026
Comment (by christinebao):
 == How to fix: ==
 The purpose of the above comparison[[BR]]
 if(NULL == wcsstr(filterText, name.c_str()))
 [[BR]]
 should be whether the filter contains secondary name ("Secondary" in this
 case), not extension name ("Join_Extension" in this case).
 Take "SecondaryID=1" for example, if it contains secondary feature source
 name, it shouldn't be treated from primary.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1208#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
