[mapguide-trac] #1131: Load balancing doesn't support failover
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 16 22:33:16 EST 2009
 Reporter:  brucedechant  |         Owner:  brucedechant
     Type:  defect        |        Status:  reopened
 Priority:  low           |     Milestone:  2.2
Component:  General       |       Version:  2.1.0
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Changes (by christinebao):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 After adding NULL pointer check, server unit test won't crash because of
 calling NULL pointer, but it still has 4 test cases fails.
 This is because of code:[[BR]]
 MgConnectionProperties* MgSiteManager::GetConnectionProperties(
     MgUserInformation* userInfo, MgSiteInfo::MgPortType portType, bool
 useSessionIp)
         if (length > MgSiteInfo::HexStringLength)
             STRING siteHexString = sessionId.substr(
                 length - MgSiteInfo::HexStringLength,
 MgSiteInfo::HexStringLength);
             Ptr<MgSiteInfo> siteInfo = GetSiteInfo(siteHexString);
             if ((NULL != siteInfo.p) && (MgSiteInfo::Ok ==
 siteInfo->GetStatus()))
                 connProps = GetConnectionProperties(userInfo, siteInfo,
 portType);
             else
                 // This site is not currently working
                 // We have a session, but it will not exist on any other
 machine so we force the session exception
                 throw new
 MgSessionExpiredException(L"MgSiteManager.GetConnectionProperties",__LINE__,__WFILE__,
 NULL, L"", NULL);
 [[BR]]
 siteInfo from GetSiteInfo(siteHexString) is NULL, and an exception throw
 out saying session expired.
 Compared with the code before:[[BR]]
             Ptr<MgSiteInfo> siteInfo = new MgSiteInfo(siteHexString);
             if (MgSiteInfo::Ok == siteInfo->GetStatus())
 portType);
 [[BR]]
 Personally I think in the GetSiteInfo(…) function, if matchingSiteInfo is
 not found, we can new an instance of it. The code could be:[[BR]]
 MgSiteInfo* MgSiteManager::GetSiteInfo(CREFSTRING hexString)
     MgSiteInfo* matchingSiteInfo = NULL;
     if (matchingSiteInfo == NULL)
         matchingSiteInfo = new MgSiteInfo(hexString);
     return SAFE_ADDREF(matchingSiteInfo);
 [[BR]]
 I tested it in unit test, and all test cases pass.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1131#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
