[mapguide-trac] #1193: Select Within cause a 500 error in the
browser
trac_mapguide at osgeo.org
Thu Dec 17 16:09:42 EST 2009
#1193: Select Within cause a 500 error in the browser
Reporter: hubu | Owner: hubu
Type: defect | Status: new
Priority: medium | Milestone: 2.2
Component: General | Version: 2.1.0
Severity: trivial | Resolution:
Keywords: Select-Within | External_id: 1246728
Comment (by chrisclaydon):
The patch now looks ok to me. I'm still a little worried about the lack of
support for multi-geometries. If the features include a poly-polygon, does
the select within function fail? Curve-polygon and multi-curve polygon
seem like they'd be much less common. Do you have any datasets that
include them?
I think you can probably submit the patch as-is. But we may need to
address related defects, if they come up, in the server code.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1193#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
