[mapguide-trac] #1211: The icon of FeatureInfo, Theme, Query and Redline should be replaced
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 18 00:40:37 EST 2009
 Reporter:  christinebao      |         Owner:  Christine Bao
     Type:  defect            |        Status:  new
 Priority:  medium            |     Milestone:
Component:  Fusion Templates  |       Version:  2.1.0
 Severity:  major             |    Resolution:
 Keywords:                    |   External_id:  1288413
Comment (by christinebao):
 Attach two patches for replacing the icons:[[BR]]
 1.
 https://trac.osgeo.org/mapguide/attachment/ticket/1211/MapGuideTemplate.patch
 is to update MapGuide template in MapGuide trac.[[BR]]
 2.
 https://trac.osgeo.org/mapguide/attachment/ticket/1211/FusionWidgetInfo.patch
 is to update fusion's widget info in fusion trac.
 Please note: The new icons appears in the flexible web layout created
 after this replacement. The flexible web layout created before still shows
 the old icons because they're defined in ApplicationDefinition once it's
 created. You need to update them manually.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1211#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
