[mapguide-trac] #1213: Maestro: consider supporting RFC50 "Hide from legend"
MapGuide Open Source trac_mapguide at osgeo.org
Fri Dec 18 14:13:54 EST 2009
   Reporter:  jbirch       |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 [wiki:MapGuideRfc50 RFC 50] allows users to hide !TypeStyles from display
 in the legend.
 Currently Maestro allows you to add/remove !TypeStyles, but not hide them.
 As far as I can tell, it would just require another checkbox "Show in
 Legend" on each !TypeStyle when using 1.3 layer schema (defaulted to
 True), and add the !ShowInLegend element.
 I can't tell from the RFC whether this only hides the item from the legend
 and still renders the feature type when encountered, or if it stops the
 rendering too.  I'm guessing the former, but will have to test.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1213>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
