[mapguide-trac] #1175: Failed to set map name using MgMap.Open
trac_mapguide at osgeo.org
Tue Dec 22 02:36:00 EST 2009
Reporter: liuar | Owner:
Type: defect | Status: closed
Priority: low | Milestone:
Component: General | Version: 2.0.2
Severity: trivial | Resolution: fixed
Keywords: | External_id: 1289006
Comment (by christinebao):
The patch looks good.
In MgResource::Open(m_resourceService, resId); m_name is deserialized from
stream, thus m_name = mapName; is override. To keep m_name is mapName as
expected, the code should be moved down.
The code is submitted on behalf of Spark Liu to fix this ticket.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1175#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
