[mapguide-trac] #459: mgserver locks up when using AGG renderer
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 23 05:46:16 EST 2009
 Reporter:  jbirch   |         Owner:  waltweltonlair
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  General  |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Changes (by trevorwekel):
  * owner:  trevorwekel => waltweltonlair
  * status:  assigned => new
Comment:
 Hi Walt, I think did an initial investigation into this defect.  Check to
 see if the data source has a Z-value.
 LineBuffer* LineBuffer::Clip(RS_Bounds& b, GeomOperationType clipType,
 LineBufferPool* lbp)
     // We don't handle 3D clipping correctly yet
     // TODO: Implement 3D clipping if necessary
     if (hasZ())
         return this;
 And I recall that I enabled clipping somewhere else in the stylization
 code base.  There may be a work in progress patch on my old laptop.  Check
 with Bruce.  The code I was working on produced an unexpected clip
 boundary along the edge of the screen so I did not submit it.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/459#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
