[mapguide-trac] #1200: Maestro: Consider adding row and column indicators for the XML editor
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 23 15:54:12 EST 2009
 Reporter:  jbirch       |         Owner:  ksgeograf
     Type:  enhancement  |        Status:  closed
 Priority:  low          |     Milestone:
Component:  Maestro      |       Version:
 Severity:  trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
Changes (by ksgeograf):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed with r4465.
 There is now a line/col indicator at the top.
 It works, but if you select something, it always shows the bottom-most
 position, rather than the actual carret position. This is due to a strange
 implementation of the .Net Textbox, where you cannot control the carret
 directly, but only manipulate SelectionStart and SelectionLength (and
 SelectionStart is alway the top-most location, regardless of the carret).
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1200#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
