[mapguide-trac] #459: mgserver locks up when using AGG renderer
MapGuide Open Source trac_mapguide at osgeo.org
Wed Dec 23 16:22:48 EST 2009
 Reporter:  jbirch   |         Owner:  waltweltonlair
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:
Component:  General  |       Version:  2.0.0
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Comment (by waltweltonlair):
 Yes, the data has Z, and so in the past it would not get clipped due to
 the code you highlighted above.  In r4226, however, I updated stylization
 so that z-values are ignored for 2D renderers, like AGG.  As a result
 clipping now happens for this dataset.
 Nevertheless, I tweaked the code so it was like before (with no clipping),
 and I could still not reproduce the problem.
 Given the change in r4226, I'm prepared to close this ticket as fixed,
 unless someone can provide updated steps on how to reproduce this.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/459#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
