[mapguide-trac] #1220: Fustion Templates - menu buttons don't work, status bar messed up
MapGuide Open Source trac_mapguide at osgeo.org
Thu Dec 24 15:35:59 EST 2009
   Reporter:  elj               |       Owner:
       Type:  defect            |      Status:  new
   Priority:  high              |   Milestone:  2.1
  Component:  Fusion Templates  |     Version:  2.1.0
   Severity:  critical          |    Keywords:
External_id:                    |
 I installed 2.1. The fusion templates have a bug. The map shows, but if I
 click on a button, e.g. View menu, Show Legend, then IE gets an error, see
 below. Also, the status bar shows nothing but the x value for the cursor
 position. Everything else in the status bar is missing.
 Running on Server 2008 & IIS. IE reports a bug on line 64883:9, "Object
 Expected". If I open auqa.index.html, Visual Studio shows a warning:
 Warning 6       Error updating JScript IntelliSense: C:\Program
 Files\OSGeo\MapGuide\Web\www\fusion\lib\fusionSF.js: Object doesn't
 support this property or method @ 1101:4    C:\Program
 Files\OSGeo\MapGuide\Web\www\fusion\templates\mapguide\GoogleAqua\index.html
 1       1       C:\...\www\
 The line at this location is: "Fusion._singleFile = singleFile;"
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1220>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
