[mapguide-trac] #842: Null pointer checks needed for GetExtent
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 11 19:49:33 EST 2009
 Reporter:  tomfukushima  |         Owner:
     Type:  defect        |        Status:  closed
 Priority:  medium        |     Milestone:  2.1
Component:  Web API       |       Version:  2.0.1
 Severity:  minor         |    Resolution:  fixed
 Keywords:                |   External_id:
Changes (by tomfukushima):
  * status:  new => closed
  * resolution:  => fixed
Old description:
> Calling GetExtent on an empty SDF will result in null pointer exceptions.
> These changes change the behavior of the API so that instead of getting a
> fatal exception, we get NULL back from the call.
> Note that this fix changes the behavior of the GetExtent API in that
> instead of throwing an exception, NULL is returned.
New description:
 Calling !GetExtent on an empty SDF will result in null pointer exceptions.
 Note that this fix changes the behavior of the !GetExtent API in that
Comment:
 r3612 and r3613
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/842#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
