[mapguide-trac] #852: Posibility to change the selection transparency with the selection color
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 12 07:18:17 EST 2009
   Reporter:  msuing       |       Owner:
       Type:  enhancement  |      Status:  new
   Priority:  low          |   Milestone:  2.1
  Component:  AJAX Viewer  |     Version:  2.0.1
   Severity:  minor        |    Keywords:  selection, transparency
External_id:               |
 When you change the selection color in
 ..\www\viewerfiles\ajaxmappane.templ, line 334[[BR]]
 var selectionColor = '0x0000FFFF'; // Blue[[BR]]
 The value is 0xRRGGBBaa where each is a hex value from 0-255 representing
 your RGB and transparency (alpha) values. [[BR]]
 Currently I’m not seeing the alpha value have any impact as either FF or
 00 so I don’t think it’s being used.[[BR]]
 It could be fantastic to have the possibility to change the selection
 transparency.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/852>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
