[mapguide-trac] #810: Generated code in MapGuideDotNetApi.dll contains a class SWIGTYPE_p_MgRenderingOptions
MapGuide Open Source trac_mapguide at osgeo.org
Tue Feb 17 18:48:23 EST 2009
 Reporter:  sam                            |         Owner:  waltweltonlair
     Type:  defect                         |        Status:  assigned
 Priority:  low                            |     Milestone:  2.1
Component:  Web API                        |       Version:  2.0.2
 Severity:  trivial                        |    Resolution:
 Keywords:  SWIGTYPE_p_MgRenderingOptions  |   External_id:
Changes (by waltweltonlair):
  * status:  new => assigned
  * owner:  => waltweltonlair
Comment:
 Besides SWIGTYPE_p_MgRenderingOptions there are other wacky types being
 generated:
  * SWIGTYPE_p_MgStream
  * SWIGTYPE_p_int
  * SWIGTYPE_p_UINT
 For !MgRenderingOptions it simply needs to be added to the list of
 published API classes.
 The other weird ones are due to either
  * methods declared as published but which shouldn't be
  * published methods using types that are disallowed
 I have it all fixed on my machine and will check things in soon.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/810#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
