[mapguide-trac] #855: Wix Installer does not configure serverconfig.ini
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 19 09:04:48 EST 2009
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  2.1
  Component:  General  |     Version:
   Severity:  trivial  |    Keywords:  installer wix
External_id:           |
 The current wix installer uses the default serverconfig.ini
 However the installer does not change the paths in that file during
 installation to match the paths defined in the installer.
 Attached is a patch that will write the correct paths to serverconfig.ini
 during installation.
 This requires that the default serverconfig.ini is replaced with one that
 has all the paths removed (also attached)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/855>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
