[mapguide-trac] #864: Temporary Files Location not Reflecting Env Vars
MapGuide Open Source trac_mapguide at osgeo.org
Sat Feb 28 09:26:50 EST 2009
 Reporter:  crispinatime  |         Owner:
     Type:  defect        |        Status:  new
 Priority:  low           |     Milestone:
Component:  Installer     |       Version:  2.0.2
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Comment (by crispinatime):
 Replying to [comment:2 jbirch]:
 Maybe this is more generic than just changing the installer?
  1) Something should be cleaning up the files?
  2) Just setting a fixedpath in the installer will set the TEMP to the
 TEMP location at install time... do the INI files support variables? If we
 could put %TEMP% in the INIfiles then changes to the Operating System vars
 would be supported by MapGuide
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/864#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
