[mapguide-trac] #1039: Possible leak in selection
MapGuide Open Source trac_mapguide at osgeo.org
Tue Jul 21 19:39:29 EDT 2009
 Reporter:  jng      |         Owner:
     Type:  defect   |        Status:  new
 Priority:  low      |     Milestone:
Component:  General  |       Version:  2.0.2
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Comment (by jng):
 That's what I initially thought, I just walked through the code from the
 starting point of MgSelectionBase::GetExtents (from that code fragment)
 and found what I thought was a spatial context reader not being closed.
 Now that this is not the case (thanks Bruce for the clarification), I'll
 guess we'll just keep on hunting for the cause of this connection
 exhaustion problem.
 Replying to [comment:1 jbirch]:
 > Jackie, is this a possible cause of the problem mentioned here?
 > http://n2.nabble.com/FW%3A--mapguide-users--MapGuide-runs-out-of-FDO-
 connections-under-Fusion-MGOS-2.1-Beta-tp3287689p3287689.html
 > It's a bit disturbing that connections are being held open; this will
 stop the server from shutting down in an orderly fashion for repository
 backups, etc...
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1039#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
