[mapguide-trac] #1042: Viewer template file streams not properly
closed
trac_mapguide at osgeo.org
Tue Jul 21 21:52:45 EDT 2009
#1042: Viewer template file streams not properly closed
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: low | Milestone:
Component: AJAX Viewer | Version: 2.0.2
Severity: trivial | Keywords:
External_id: |
In MgDev/Web/src/mapviewernet/common.aspx:
The LoadTemplate() method does not close/dispose of the stream reader
after reading the template contents.
This results in a dangling stream reader for each template request.
Will invetigate to see if other languages are affected too.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1042>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
