[mapguide-trac] #1043: Tiling get offseted from standard layers when resizing browser
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 22 05:39:16 EDT 2009
   Reporter:  bscott       |       Owner:
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.1
  Component:  AJAX Viewer  |     Version:  2.0.2
   Severity:  minor        |    Keywords:
External_id:               |
 To reproduce
 In the sheboygan tiled map, Move the district layer from the base group to
 the standard not tiled layers.
 Open the layout in your browser (tested on IE) and play with the maximize
 and normalize button.
 Tiled layers display in the wrong places while the non tiled layer is OK.
 There is a pretty simple patch to fix this defect.
 The ajaxviewer try to optimize the setting of the tile url with a "loaded"
 flag.
 If we remove this optimisation, everything work fine.
 This optimisation is not realy visible as there are never thousand of
 tiles.
 So i suggest to remove this optimisation as it cause a defect
 Bruno Scott
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1043>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
