[mapguide-trac] #1045: Measure tool should not use GetResourceContent to check if resource exists
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jul 22 10:12:06 EDT 2009
   Reporter:  bscott       |       Owner:
       Type:  defect       |      Status:  new
   Priority:  high         |   Milestone:  2.1
  Component:  AJAX Viewer  |     Version:  2.0.2
   Severity:  major        |    Keywords:
External_id:               |
 The measure tool uses GetResourceContent to check if the resource exists
 This is causing an exception in the error log
 We should avoid as much as possible exceptions as they are causing memory
 leaks
 see this nabble thread:
 http://n2.nabble.com/Huge-memory-leaks-in-Mapguide-Exceptions-
 td3231610.html#a3231610
 As the ResourceExists is now working, we should use it instead.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1045>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
