[mapguide-trac] #889: FDO Componentized install
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 24 11:55:27 EDT 2009
 Reporter:  jng          |         Owner:  jng
     Type:  enhancement  |        Status:  new
 Priority:  low          |     Milestone:  2.2
Component:  Installer    |       Version:
 Severity:  trivial      |    Resolution:
 Keywords:               |   External_id:
Comment (by jng):
 Changes added r4076
 Tested both install and change (post-install) and this works great!
 There are still some small things left to do:
  * Build and copy FdoRegUtil to the Server\FDO directory as part of the
 "prepare" step
  * Initially disable the ArcSDE, MySQL, King Oracle and PostGIS providers
 (since these require external libraries present). The xml fragment which I
 thought would work actually doesn't work.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/889#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
